Hello and thanks for the responses,
The goal is to study the feasability of eliminating one antenna, I am already taking into account that that is complex.
I am using two CC2500 from TI in separate channels, doing TX/RX (half duplex, internally controlled), with a 200mW amplifier downstream on each channel. I think they are used in ZigBee, 802.15.4, R/C toys and small area network architectures. The antennas are standard 5-6dBi RPSMA omnidirectional like those installed on AP's.
They could indeed transmit and receive at the same time. The TX will be amplified on both ends. And for the application, it is more feasible to install amplifiers than another antenna.
@thewyliestcoyote: What do you mean by "odd numbered of port devices", would you please explain that?
Many thanks.
