Author Topic: MESR 100 v2 leads  (Read 2016 times)
Offline NoidzoidTopic starter
MESR 100 v2 leads
« on: June 21, 2018, 12:12:03 am »
Hello one and all
Could someone tell me why the leads that came with this meter are so short (I'm assuming there is a reason), and is there any reason why I shouldn't change them for something longer with probes on the end rather than the cumbersome alligator clips that are difficult to use in small spaces.
Sorry if this is a dumb question but I really am quite new to this.
Many thanks in advance to anyone shedding light on this.
Online wraper
  • Country: lv
Re: MESR 100 v2 leads
« Reply #1 on: June 21, 2018, 12:42:22 am »
You'll get more error in readings with long leads. Also if you use long leads, both of them should be attached together to basically make a single cable, otherwise readings will significantly vary depending on the cable position because of series inductance change.
The following users thanked this post: Noidzoid
« Reply #2 on: June 21, 2018, 01:21:14 am »
Thanks for the reply Wraper.
Do you mean the wires should be taped/twisted together so they are close to each other but not actually connected (core to core)?  If this is the case I will make up a new set. One of the reasons I bought this unit was that I thought it could be used to test capacitors without having to remove them from the board, but the short length and awkward clips don't make it easy.
Online wraper
  • Country: lv
« Reply #3 on: June 21, 2018, 08:41:37 am »
You could tape them together at say each 10 cm of distance.
« Reply #4 on: June 21, 2018, 07:34:44 pm »
Many thanks Wraper much appreciated
Offline hugo
« Reply #5 on: June 22, 2018, 12:17:13 am »
« Reply #6 on: June 22, 2018, 06:54:22 am »
Would twin speaker cable be suitable? There would be no need for the tape. Banana one end, pointy probe the other.
