I was reading some question in order to prepare some students for a test. One question (translated) is:
Draw the static characteristic curve of a voltmeter, with 0 volts Zero Offset, with range 0:100% -> 0:300V, absolute error +3 volts at 10v and relative error 1% at 200V.
The answer (don't even know if it is correct. In fact I don't now if the question is correct) is the above drawing, with no explanation.
I search every book I own with metrology, electrical measurements errors and instruments. I could not find any relative reference to the above.
I can understand the point at 200,2. 1% relative error at 200V is 2volts. I can understand the graph starting a 0,0 as the 0 volts Zero Offset. Is the point at 300,5 a sum of relative error and absolute error?
Alexander.
