Good time of the day,
Brief intro:
I am exploring the
STM32F303VC peripherals on the
STM32F3-Discovery board and now I would like to utilize the ADC and DAC modules.
The idea is to capture sound (voice) with the microphone, digitize it via ADC, store result inside the MCU and play it back via DAC.
As a mic I've chose Electret Condenser Microphone (BCM-9754P
pdf) as it is easy accessible in my area.
As a op-amplifier I've chose TI NE5532P (
pdf). Because of its affordability and low-noise.
I plan to use 5V supply from a board for op-amp and 3.3V (in fact ~2.95V) supply for all other stuff.
And the question is - how to connect/wire this things together?
I've found alot schematics on the internet but I lack expirience and knowledge to understand them well. This is where I ask you for help.
First variant looks like this (taken from
here):
While the purpose of all components is desribed in the suorce I don't understand why or for what purpose those voltage dividers (R1R2 and R6R7) are used /needed. How they infuence o nthe result and can I remove them?
Secend variant that I consider looks this way: (taken from AVR335: Digital Sound Recorder
datasheet)
Here the voltage divider R2R3 is used on non inverting input (why, what if not?)
Plus the inverting amplifier connection is used - why this is acceptable? Shouldn't this influence the ADC results?
Will be very greatfull for any help!
