Hi All
I am not sure if this topic would be best suited listed under Beginners or Projects section of the forum so please move as needed.
I am trying to work out the best way to drive two solenoid valves from a micro-controller, but both the micro-controller and the solenoid valves are on there own isolated power supplies and I can not share the power or ground rails.
The simplest way I can thing about doing this is by using optocouplers and mosfets.
Here is what I am thinking about using, I have not yet decided on the components to use, that is why there are no part numbers and or values listed.
Before I think about things to much, will the above work, or is there a better way?
Thanks for your time.
Best Regards.
