To be honest, the type of soldering station is not overly important (as pretty much all of em have a wide variety of tips, and the tips is what essentially makes the difference!) there are different shapes/sizes that are suitable for different purposes. Also, when it comes to SMD work, most of the time, you'd be working with hot air (and not a soldering iron, although, that too has it's uses in that department), also, using a microscope is critical (as you wouldn't be able to clearly see what you're doing otherwise!). Anyways, I've compiled a list of various equipment (that is useful for SMD/Soldering works, as well as working with electronics in general). You may (or may not) need everything on it (depending on what you'd be doing, or if you already have some of it handy) but it's a very comprehensive and useful list (that I'm sure a lot of people would find handy!):
So, here it is:
Soldering Station:
https://www.banggood.com/Digital-Soldering-Iron-Rework-Station-Adjustable-Temperature-T12-Welding-Handle-p-1122692.html?rmmds=search&cur_warehouse=CNSet of tips:
https://www.banggood.com/T12-Series-Solder-Iron-Tips-for-Hakko-Soldering-Station-FX-951-FX-952-p-932701.html?rmmds=search&cur_warehouse=CNTip Thermometer (useful for calibration):
https://www.banggood.com/DANIU-FG-100-Soldering-Iron-Tip-Thermometer-Temperature-Tester-0-700-p-952899.html?rmmds=searchTip brass cleaner:
https://www.banggood.com/BEST-Wire-Sponge-Soldering-Iron-Tip-Cleaning-Clean-Ball-Remover-p-84441.html?rmmds=search0.3MM Solder:
https://www.banggood.com/6040-0_3mm-50g-Tin-Lead-Rosin-Core-Solder-Soldering-Wire-p-943830.html?rmmds=search&cur_warehouse=CN0.5MM Solder:
https://www.banggood.com/6337-0_5mm-Tin-Lead-Rosin-Core-Soldering-Iron-Wire-Reel-p-946006.html?rmmds=search&cur_warehouse=CN0.8MM Solder:
https://www.banggood.com/6337-0_8mm-Tin-Lead-Rosin-Core-Flux-Solder-Soldering-Welding-Iron-Wire-Reel-p-992684.html?rmmds=search&cur_warehouse=CNFlux (apply with a tooth pick, must have):
https://www.banggood.com/NC-559-ASM-TPF-Flux-Anti-Wet-No-Clean-100g-Cream-AMTECH-Solder-Paste-p-975156.html?rmmds=search&cur_warehouse=CNSolder Paste (must have for soldering tiny SMD parts, as well as ICs, using a soldering iron for these can be tricky sometimes):
https://www.banggood.com/Wholesale-50g-Mechanic-Soldering-Solder-Welding-Paste-Flux-MCN-300-SMD-SMT-Sn63Pb37-Tool-p-50581.html?rmmds=search&cur_warehouse=CNSet of Syringes (for the paste):
https://www.banggood.com/5Pcs-5ml-Syringe-Crimp-Sealed-Blunt-End-Tips-For-Makeup-DIY-Glue-Oil-Ink-p-1084357.html?rmmds=search&cur_warehouse=CNSet of solder wick (10 rolls):
http://www.dx.com/p/wlxy-wl-2015-2-0mm-copper-desoldering-wires-golden-255325Hot Air Station:
https://www.fasttech.com/products/0/10035521/7757304-yihua-8858-650w-portable-led-electric-hot-airSet of extra hot air nozzles *non-essential, but can make certain tasks easier*:
https://www.banggood.com/15pcs-852-850-Nozzle-Hot-Air-Stations-Gun-Rework-BGA-Nozzle-For-Soldering-Station-p-1258908.html?rmmds=search&cur_warehouse=CNHot Air Stand *non-essential, but can make certain tasks easier, as you'd have one hand free by using it*:
https://www.fasttech.com/products/0/10022341/4821000-kaisi-f-204-hot-air-gun-cell-phone-repairHeat Insulation Pad:
https://www.fasttech.com/products/0/10034091/7717502-magnetic-heat-insulation-pad-desk-mat-maintenanceDigital Microscope (a must have for working with tiny SMD components/ICs!):
https://www.fasttech.com/products/0/10041165/9620913-andonstar-a1-i-b-500x-magnifier-usb-digitalPCB Holder #1:
https://www.fasttech.com/products/0/10029832/6533600-baku-bk-687-adjustable-mainboard-pcb-cardPCB Holder #2:
https://www.fasttech.com/products/0/10005722/7600600-pro-skit-sn-390-pcb-printed-circuit-board30 AWG Hookup Wire:
http://www.dx.com/p/rxdz-p-n-b-30-1000-insulated-pvc-coated-30awg-wire-wrapping-reel-200m-green-500249Multimeter (Option 1):
https://www.fasttech.com/products/0/10002748/6659300-uni-t-ut139c-handheld-true-rms-digital-multimeterMultimeter (Option 2):
https://www.fasttech.com/products/0/10045104/9620280-aneng-an860b-true-rms-digital-multimeterMultimeter probe set:
https://www.fasttech.com/products/0/10031011/9632282-p1300c-universal-multimeter-probe-leads-kit-14Set of prying tools (for opening phones/tablets or anything plastic that doesn't have screws basically):
https://www.fasttech.com/products/0/10046939/9623407-kaisi-6-in-1-dual-end-metal-spudger-pryingSolder assist tools (helps with removal of certain components, as well as opening joints with excess solder):
https://www.fasttech.com/products/0/10005062/1397600-sa-10-6-piece-carbon-steel-solder-assist-tools-setSet of tweezers (also helps removing certain components, such as ICs, and holding tiny SMD components as you remove em):
https://www.fasttech.com/products/0/10009342/1827801-wlxy-wl-esd-durable-steel-tweezers-set-6-pcsScrewdriver set (contains all the bits you need to open up pretty much any screws!):
https://www.fasttech.com/products/0/10002669/2285300-huijiaqi-no-8921-53-in-1-precision-screwdriverMicro Nippers:
https://www.fasttech.com/products/0/10009316/3825601-authentic-santus-st-109-5-wire-cuttersDiagonal Cutters:
https://www.fasttech.com/products/0/10010005/1880905-best-5-alloy-steel-pvc-diagonal-side-cuttingCable outer insulation remover:
https://www.fasttech.com/products/0/10002624/1195500-network-and-connection-wire-cutter-toolsSet of heatshrink tubing:
https://www.fasttech.com/products/0/10021482/7843300-heat-shrink-tubing-wire-cable-sleeving-wrap-tubeKapton tape:
https://www.fasttech.com/products/0/10012975/2187001-kapton-polyimide-high-temperature-resistantElectrical tape:
https://www.fasttech.com/products/0/10009892/1868503-3m-1500-pvc-electrical-insulation-adhesive-tapeUtility Knife:
https://www.fasttech.com/products/0/10022130/4781600-lodestar-l612303-high-carbon-steel-cuttingSeveral things to note:
1. In order to cleanup flux residue, you should be using IPA (isopropyl alcohol) of preferably 90% purity or higher (along with q-tips)
2.Both the soldering & hot air stations I mentioned are worldwide compatible (electricity wise, both do 110-240V)
You just need to use the correct micky mouse/IEC cable for your country.
3. Solder paste has to be refrigerated after opening!
If you don't wanna use your actual fridge, you could just get this small USB one for this purpose:
https://www.fasttech.com/products/0/10033047/7240601-2-in-1-mini-usb-fridge-freezer-refrigeratorYou don't have to plug it into a computer USB port (any 5V phone charger with a USB port would do!)
4. The microscope is of great quality, in fact, Dave did a review about it back in the day, which you can see here:
Alternatively, there's also the G600 around the same price (and there are two versions of it, one with a plastic stand and another with a metal one) and it also has a built-in 4.3" display (but it doesn't come even remotely close to the Andonstar in terms of color reproduction and sharpness!) so I wouldn't go with that one.
