Before I say what this is for, please bear two things in mind.
1) It is an educational project
2) I've been watching too many poncy cookery programmes on telly....
The plan is to make a "programmable hotplate". I can program it for example to "Ramp from ambient up to 60C in 15mins. Hold at 60C for one hour. Increase to 90C as quickly as possible. Hold for 30mins.... etc etc etc etc....
1C absolute temperature precision should be enough, but I would like quite slightly better relative control - ie I don't mind if it's only within 1 degree of its setpoint, but I would like it to stay pretty close to where-ever it settles.
Planning to use two PT100s, which will be in the cooking medium. (Using the average of the two readings, with an alarm & shutdown if the deviation exceeds a certain limit.
Using only full cycles to avoid creating a DC offset on the mains makes sense.
I do indeed have a fair bit of controls knowledge, having spent many an hour tuning control loops on heavy automated hydraulic machinery...
Thanks for all the advice thus far.
