Youre near sighted, so you should be in luck, I'm nearsighted (I forget how bad, but it aint good, 12 point font at around a foot away to be pretty clear). Ive had luck using stereo microscopes both with and without glasses (much more convenient with glasses on, when you have to do stuff thats not under the microscope) I'm not sure about if youre far sighted, so I cant say either way on that. Make sure the microscope has either a diopter adjustment on one eye piece, or at least set-screws to hold the eye pieces in place, you can tweak the position of the eye piece slightly and use the set screw to hold it so they both are in focus. The twist diopter adjustment is obviously preferred. If it has neither, and the eye pieces just drop into place, you could always shim one.
