hello,
I am quiet new to programming so please bear with me, but I have tried to copy a CAN project from "Advanced PIC Microcontroller Projects in C" by Ibrahim. Page 475 onwards if you are interested.
I see that the author has used mikroc for its convenient CAN functions, which he mentions on page 499. I intend to use the PIC18F258, with the MCP2551 CAN transceiver, however I cannot get the code on page 511 (the collector node) to compile. mikroc tells me that on line 31 " Invalid declarator expected'(' or identifier" and on line 37 " '}' expected ';' found". I am not entirely sure what these mean, and I have tried googling for an answer, but I would think that the book's example should be at least working. :/
Could somebody explain what these errors mean, and how I should think about fixing them please?
My code is as follows:
void main()
unsigned char temperature, data[8]; // LINE 31
unsigned short init_flag, send_flag, dt, len, read_flag;
char SJW, BRP, Phase_Seg1, Phase_Seg2, Prop_Seg, txt[4];
unsigned int temp;
unsigned long mV;
long id, mask;
TRISA = 0xFF; // PORTA are inputs LINE 37
TRISB = 0x08; // RB2 is output, RB3 is input
// Configure A/D converter
ADCON1 = 0x80;
// CAN BUS Timing Parameters
SJW = 1;
BRP = 1;
Phase_Seg1 = 6;
Phase_Seg2 = 7;
BRP = 1;
Prop_Seg = 6;
init_flag = CAN_CONFIG_SAMPLE_THRICE &
CAN_CONFIG_PHSEG2_PRG_ON &
CAN_CONFIG_STD_MSG &
CAN_CONFIG_DBL_BUFFER_ON &
CAN_CONFIG_VALID_XTD_MSG &
CAN_CONFIG_LINE_FILTER_OFF;
send_flag = CAN_TX_PRIORITY_0 &
CAN_TX_XTD_FRAME &
CAN_TX_NO_RTR_FRAME;
read_flag = 0;
// Initialise CAN module
CANInitialize(SJW, BRP, Phase_Seg1, Phase_Seg2, Prop_Seg, init_flag);
// Set CAN CONFIG mode
CANSetOperationMode(CAN_MODE_CONFIG, 0xFF);
mask = -1;
// Set all MASK1 bits to 1's
CANSetMask(CAN_MASK_B1, mask, CAN_CONFIG_XTD_MSG);
// Set all MASK2 bits to 1's
CANSetMask(CAN_MASK_B2, mask, CAN_CONFIG_XTD_MSG);
// Set id of filter B1_F1 to 3
CANSetFilter(CAN_FILTER_B2_F3,500,CAN_CONFIG_XTD_MSG);
// Set CAN module to NORMAL mode
CANSetOperationMode(CAN_MODE_NORMAL, 0xFF);
// Program loop. Read the temperature from analog temperature
// sensor
for(;;) // Endless loop
// Wait until a request is received
dt = 0;
while(!dt) dt = CANRead(&id, data, &len, &read_flag);
if(id == 500 && data[0] == 'T')
// Now read the temperature
temp = Adc_Read(0); // Read temp
mV = (unsigned long)temp * 5000 / 1024; // in mV
temperature = mV/10; // in degrees C
// send the temperature to Node:Display
data[0] = temperature;
id = 3; // Identifier
CANWrite(id, data, 1, send_flag); // send temperature
Note, I have removed a large comment from the code in the book, but I have commented the two lines in question.
thank you all.
