Ok, I bought a electret microphone from the local seller, Installed and shielded, with a 3.5 jack plug. I got good results: noise is almost gone, and you can clearly hear the difference.
Now I've cooled down the CMOS sensor and the main BGA with an heatsink.
Doing the first tests today.
Also, soldering in a high density board without a microscope is very hard!
