Some recommendations:
of course, one should have some of the 'classics', even if only as a bad example.
And some of them are passable and quite forgiving.
LM301, LM741, LM324, TL071/2/4 (or 08x)
intermediary Generation
NS LPC660IN OPA, Low-Power quad CMOS, r2r-out, <1mW, 2fAb ~3mVos, 0.11V/µs 0.35MHz CMRR>63db >1TOhm
LTC LT1013/1014 OPA, Dual/Quad precision low noise, os<300µV/1nA, Ib<30nA, Avol2.5V/µV typ, 500kHz 0.4V/µs, CMRR114db typ.
LTC LT1077 Micropower/precision OPA, 250kHz 0.12V/µs, single supply; Ib<11nA, os<60µV/350pA, 60µA max.
NE5532/5534, low noise OPAs. the audio people seem to love them
AD822 Dual precision, r2r, Low-Power, FET-Input OP,
AD845 Precision, 16MHz CBFET OPA,
TLC2272/4 OPA, LinCMOS Dual/Quad r2r, low noise, typ Ib1pA os300µV
And now some nice ones:
LTC LT1468/1469 bipolar 90MHz, 22V/ms 16-Bit Accurate Operational Amplifier
despite its performance, it behaves rock-solid! Solved many problems for me.
LT1800/1801 OPA, Low Power R2R In/Out Precision 80MHz
AD8512 OPA, dual JFET Precision, Wideband, very low Noise, low Bias Current
AD8522 Dual Zero-Drift, Single-Supply, r2r Input/Output OPA
ADA4077 OPA, High Precision, Low Offset and Drift, 4MHz 7nV/Sqrt(Hz) (NextGen OPxx77)
LMP2021MA OPA, Zero-Drift, Low Noise EMI hardened, r2r out
TLE2021 OPA, Excalibur Precision, High-Speed, Low-Power, ext. Adj. (and other TLE202x)
TLE214x OPA, single/dual/quad Excalibur BiFET Low-Noise High-Speed Precision;
ADA4857 OPA, ultra-low Distortion, low Noise, high Speed, power-down Input
LMH6612 OPA, Dual, Single Supply 345 MHz Rail-to-Rail Output
