Arguably, it might be more important, because although the leakage is lower (uA?), there isn't a self-balancing effect to it. And if one capacitor eventually ends up overcharged, its capacitance (and therefore the total capacitance) will drop precipitously , as the dielectric saturates. (There's absolutely no danger of breakdown -- a 16V cap might finally arc over beyond 100V.) So you'd still want resistors, but the values can be larger because the expected leakage is smaller.
I would much better recommend using good old electrolytic or tantalum for your purpose, or if low ESR is needed, aluminum polymer.
