Author Topic: Modding Registered/Buffered DIMM Memory Possible?  (Read 936 times)
Offline sean0118Topic starter
« on: May 12, 2015, 12:29:41 pm »
I'm guessing this is a long shot, but is there a way to disable the register on registered/buffered computer DIMM memory?
I've found a datasheet for the type of register I mean here. I can't see any glaring DISABLE function...   :(
If there is a solution I'm guessing it's near impossible due to the use of SMD BGA packages?   Thoughts?  :-/O
« Last Edit: May 12, 2015, 02:25:29 pm by sean0118 »
