I have built an HV power supply using a 12V DC input. I'm sending the circuit diagram of it. I want it to modify it to work on my mains supply for more power.
-----------------SNIP------------------------------
My mains power supply rates 220V 15A.
*My question is : What do I want to do to make it suitable for an 220V AC input?*
There are likely quite a few readers who are very very concerned that you're taking on
a very dangerous task without even a rudimentary understanding of the hazards
of your undertaking.
You clearly are an ambitious and imaginative person. You may even do great things.
But this isn't one of them.
If you want to make a mark or build something useful, start with some projects that will
teach you useful lessons. Getting killed by a flyback transformer is not a useful lesson.
If energy conversion is interesting to you, build some heaters. Experiment with low temperatures.
Buy some peltier coolers. Experiment with solar, or LiPo cells.
If building a big energy discharge apparatus is really really what you want to do, then
learn enough about it that you can reason on your own through the circuit design and
the safety considerations. Start with low voltage primaries (as you have) and thoroughly
understand all the effects, both first order and second order (as you have
not). And
note that with high-energy designs, the "second order" effects can present first order
dangers. You need to understand the fundamentals. Until you do, you're just screwing
around with high voltages and putting yourself at risk. That's not engineering, its irresponsible.
Sure, you may complete this project without killing yourself. But to what benefit?
Do it right. Start from the beginning. Learn the principles. Build something that you
understand.
