Hi all!
Recently acquired an old (~2000 vintage) non-functioning rackmount Dell Poweredge server.
So I thought I would harvest it for parts. Some of the design is quite interesting too!
On the motherboard there were three vertical removable daughter-boards which appear to be 4-way SMPS boards. (see "4Way_SMPS" photos).
There were also three soldered daughter-boards which appear to be 2-way SMPS boards. (see "2Way_SMPS" photos).
At some point I will reverse engineer them and work out what voltage input/output they regulate! From the server PSU I guess it's a 12V input!
I guess they made them daughter-boards for better heat-sinking and the removable ones so they could be replaced if they failed.
I also notice a distinct lack of electrolytic capacitors on the boards. There were about 10% of the number I'd expect on a motherboard. I guess so as to limit the points of failure.
I hope the photos are of interest to someone out there!
http://imgur.com/a/Mqdyu
