I have recently built a simple dummy load, the one from Dave's video.
I haven't used a logic level mosfet as Dave suggested but I used simple BUZ11. Why? In datasheet there is a graph "Output characteritics" which shows that at 4V gate to source voltage (5 volt Vcc - non rail to rail op amp clipping, what I am getting at op amp output), it should be able to pass about 2.5A. So I thought it will be ok.
The problem is that it does not do that... I am able to get 400-600mA tops, varying with Vds. Am I reading this graph correctly?
Marcin.
