Author Topic: Mosfet With Middle Pin Missing?  (Read 12271 times)
Offline EpicIntelGamerTopic starter
« on: August 02, 2013, 10:17:22 pm »
Hi guys!
I was scraping two computer PSU's, just ripping all the parts off and I found something interesting.
There is a ST P10NK60Z N Channel Mosfet mounted to a heatsink and for some reason the middle pin is cut off?
The back of the fet has an insulating pad behind it so they arent using that in place of the pin, what could you use a Mosfet for with a pin missing?
Thanks!
Offline 8086
    • Circuitology - Electronics Assembly
Re: Mosfet With Middle Pin Missing?
« Reply #1 on: August 02, 2013, 10:26:33 pm »
A diode
« Reply #2 on: August 02, 2013, 10:31:53 pm »
A diode
Wow really?
With what sort of specs?
Offline 8086
« Reply #3 on: August 02, 2013, 10:36:38 pm »
A diode
Wow really?
Well that depends.  :) Usually not very exciting, with a slightly higher forward voltage than a "normal" diode.
If you look at a symbol for a MOSFET you will usually find the diode in there.
« Reply #4 on: August 02, 2013, 10:40:04 pm »
A diode
Wow really?
Oh yeah I guess they do. I don't usually look at that little diagram.
What would make them use a mosfet like this instead of a normal diode?
« Last Edit: August 02, 2013, 10:45:13 pm by EpicIntelGamer »
Offline senso
  • Country: pt
    • My AVR tutorials
« Reply #5 on: August 02, 2013, 11:16:36 pm »
Wireless gate control  :-/O
« Reply #6 on: August 02, 2013, 11:17:19 pm »
« Last Edit: August 02, 2013, 11:21:41 pm by EpicIntelGamer »
Online Andy Watson
« Reply #7 on: August 02, 2013, 11:36:21 pm »
If it was the middle pin it looks like it would have been the drain that was cut off. You wouldn't want to leave the gate floating. Still a bit odd.
« Reply #8 on: August 03, 2013, 01:36:43 am »
Yeah its the middle pin and I'm sure I didn't break it off while removing it because I looked at the PCB and there is actually no hole for that middle pin.
Perhaps they needed a diode but had that mosfet sourced for cheap?
Offline Towz
  • Country: pe
  • this avatar gallery is so awesome o.o
« Reply #9 on: August 03, 2013, 05:49:20 am »
maybe a picture of the setup would be useful. All i can think of at the moment is some sort of peak/transient suppresion since it's the Drain that is cut off. This mosfet has built in zener protection between the gate and the source.
« Reply #10 on: August 03, 2013, 06:33:51 am »
I'll grab a picture for you tommorrow, it's pretty late right now.
Offline amyk
« Reply #11 on: August 03, 2013, 06:57:18 am »
It's two 30V zeners back-to-back, so maybe that's what they were using it for. Might've been cheaper if the same part was already used in the PSU for switching, than to add another part to the BOM.
Offline smashedProton
« Reply #12 on: August 03, 2013, 07:07:55 am »
Wouldn't it be just a low inpeadance connection?  In most packages, the center pin is connected to the case.  Maybe the case on this fet isn't connected to the substrate.
 I used to cut off the middle pins of a n channel and p channel fets and solder them directly together for an active breaking system I put in by buddys airsoft gun.
« Last Edit: August 03, 2013, 07:16:15 am by smashedProton »
http://www.garrettbaldwin.com/
Invention, my dear friends, is 93% perspiration, 6% electricity, 4% evaporation, and 2% butterscotch ripple.
Offline Neilm
« Reply #13 on: August 03, 2013, 12:06:26 pm »
I have seen some packages like this that have two matched diodes in them. The case is common and each leg is one connection to the diode.
Neil
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
« Reply #14 on: August 03, 2013, 10:30:12 pm »
Neil
Yeah it has some of those dual doide packages but this is not one of those. This is an N Channel Mosfet (details in the OP) that they cut a leg off of.
Offline c4757p
  • adieu
« Reply #15 on: August 03, 2013, 10:40:48 pm »
Dear god.... flip it over and trace out that section of the circuit!  |O ;)
« Reply #16 on: August 03, 2013, 11:06:50 pm »
Will do, just a second...
« Reply #17 on: August 03, 2013, 11:10:41 pm »
I just tried but really it goes all over the place.
The one side of the mosfet goes over to one side of one of the big filter capacitors on the rectified input.
The other breaks off to multiple locations including some little 8pin IC and then it apparently also goes to the same place as the other side of the mosfet.
Offline Rufus
« Reply #18 on: August 03, 2013, 11:53:40 pm »
This is silly.
If the drain wasn't connected you are left with gate to source capacitance and wimpy ESD protection diodes as the only accessible components neither of which are useful or require mounting on a heat sink.
How was it fastened to the heat sink? With a screw to make the drain connection I'll bet and the silicon insulator pad was there just for thermal reasons.
Offline Psi
« Reply #19 on: August 04, 2013, 12:01:47 am »
Was it a cheap china powersupply? Might be from a batch of diodes that got wrongly stamped as mosfets.
They could be using them up since they're a surplus/cheap stock of diodes.
This sort of manufacturing mistake happens more often than you know.
Someone at the semiconductor plant sets the machine wrong and before they know it they have 100 reels of diodes marked as mosfets.
« Last Edit: August 04, 2013, 12:05:59 am by Psi »
Offline c4757p
  • adieu
« Reply #20 on: August 04, 2013, 12:07:58 am »
All PCBs do. It's good reverse engineering practice.
Offline c4757p
  • adieu
« Reply #21 on: August 04, 2013, 12:09:21 am »
Good point. Probe them dammit! You've got to figure these things out for yourself! ::)
