For your 136kHz amp, right?
Why not control the input in the first place, so it doesn't produce transients? I think there was a buck controller in there, or something..?
Nods sheepishly, the dreaded 136 kHz amp.... When it's behaving it's great, I made my first trans Atlantic contact the other day, UK to East coast USA. I wish I could stop the transients. I have rebuilt it to two different designs, different FET's, different driver chips, different output transformers, different filters. But I am 90% sure the signal feeding it, which is a sine wave, then pre amplified, then doubled in frequency is the issue. It neither starts, nor, stops, cleanly. the square waves start and stop noisily with none 180 degree separation. I am now getting a bit desperate, hence MOV's but they seem to have a lot of capacitance, which may upset the snubbers. The drain wave forms, when running, are very good. I am also thinking if it's feasible to awit the waveform settling before powering the PA FET's, but it would be complicated timing it right I guess.
