Hello everyone, I didn't double-check the solder I was getting and accidentally bought a roll of Multicore HMP Ersin 366 solder wire, which is apparently a high melting point solder formulation (93.5% lead 5% tin 1.5% silver) with "extra activated" 1% Halide flux core, for ultra fast line assembly hand solder, difficult solder surfaces, increased creep resistance, operating temps -200C to +250C, blablabla...
That's all neat, but it's pretty wildly different from the standard 60/40 or 63/37 rosin activated stuff I was thinking of getting. As a beginner who has never soldered before, can I use this stuff with relatively little extra trouble or would it be worth it to try and exchange with Digi-key for something more standard? My iron can handle it (brand new Hakko FX-888D), but I'm worried I'll make messes on boards with that extra activated 1% Halide flux, or that I'll be restricted in the kind of components I can solder due to that high melting point...
Side question, I'm a bit of a perfectionist and I'd like to clean the flux residues and produce really nice-looking boards, so what can I actually use to clean either that 1% halide extra active flux or the normal rosin flux? Is 99% alcohol and kimwipes okay, or do I need a special solvent? If for example I need a special solvent for HMP solder but not the standard stuff, then that would be one more reason to try and make an exchange or buy another roll sooner...
