ATX supplies have multiple voltage rails. If you need 7 volts, can you just hook something up between the 12v rail and the 5v rail? I'm assuming the 5v rail has a diode or something to prevent power from flowing back into the power supply, so where would the current go?
Thanks,
Dave
