What does that unlabeled flush knob in the center do?
I think that the up/down sets the solder iron temp when it is on and the air when it is on (correct?), but to which do they apply when both are on?
The thing in the center is a metallic QC sticker that says it Passed.
If both the hot air and the iron are on at the same time the select button steps through the three hot air digits and then the three iron temp digits.
If you turn down the hot air temp and lift the gun to use it before it cools to the lower temp it gives out quite a loud warning beep to tell you it's still hotter than the setting.
*** Here's a warning. *** Always set the hot air gun back in the holster (the heater will turn off) and let it reach the cool down point before you turn it off. Once it reaches 100 you get three dashes and the fan stops. Then turn it off. If you just cut the power and air does not move through it when it's hot your asking for trouble.
