Ok than. I will keep it in mind for future projects, where the space really matters. Thanks!
Congrats too you 300th post btw.
@zapta: Wow, thanks for you efforts! I live in Germany and I found the silkscreen to be quite expensive (15€ or so).
* I just used the set-up from a tutorial - I guess it should stabilise the signal to avoid an accidental reset.
* Does that really matter? As long as it gets pulled up it should work?! (I was planning to use the internal pullups)
* Good hint.
* I haven't thought about that feature and checked it the hard way
, but I'll try it out now.
* I haven't yet chosen the case.
* Good idea! But how do I do it? I cant plant a via on an existing pad...
* You've got a sharp eye
! Actually I was looking at a 10µF capacitor when I took the measurement.
* Yeah that's right. I thought the big one on the input-side would may do it.
* I also haven't thought about that, but I will eventually use them at the same time to indicate an accepted button-push or something like that.
