They are Wun Hung Lo-brand electrolytics, 2.2uF. 76 Hz is reasonable for the tolerances given (those resistors are 1%, but the capacitors are something on the order of holy-shit%). If you need 60 Hz accurately, add a trimmer, or even use a crystal.
Edit: The caps clock in at 2.1uF and 2.2uF, so pretty much perfect. However, those values actually give a frequency of about 70 Hz, so 76 is close. It's the circuit design that's off, not the build.
