Friend wanted me to solder a breakout board for him. Thought i'd make a video out of it to help others.
https://youtu.be/5YWX354vPqQ
Subscribe for more beginner tutorials - next video will likely be measuring the speed of sound
Not to be a party pooper, but while your tutorial isn’t bad, the world needed another amateur soldering tutorial like a hole in the head — YouTube is full of awful soldering tutorials by amateurs, a few good ones by amateurs, but there are also plenty of them from experts that show it better than any hobbyist could. (As always, I recommend the videos by Pace Worldwide. They’re from the 80s, but are brilliant.)
I do give you high marks for the clarity of the recording: everything is in focus, framed well, and the audio is clear.
Anyway, as others have said, the solder shouldn’t be balling up on the tip. It is probably oxidized and needs therapy with tip cleaner as others said. Once you’ve done that, then be sure to follow proper tip care: always re-tin!! You don’t tin, then wipe, then go solder. Instead, wipe, tin, and solder. And critically, whenever you put the iron back in the stand, tin it generously first! The layer of solder will protect the tip from oxidation. (What you don’t want to do is what almost everyone does instinctively: wipe the tip and then put it straight in the stand. That’s the worst for the tip because you’ve removed all the protective solder.)
The bit of solder added to the tip to aid in heating is called a thermal bridge, btw.
Finally, those joints have a bit too much solder. They should be concave, not convex. (I do recognize that this can be hard with many boards, whose solder pads are frankly much too small, causing the solder to kinda ball up along the component leg.)
