Good advice here today, as usual
It looks very similar/same? to the Trio-Kenwoods with a nice easy layout, all the functions and knobs at your fingertips
If everything is CONFIRMED WORKING it's a no brainer at a reasonable price.
Buying a cheap dud and having to repair it is unpaid work, zap risks and guaranteed newb drama
If the dials and switches are a bit stiff or noisy, working them a bit when the unit is switched off usually gets them going again
The trace should be bright and SHARP when adjusted accordingly.
I still use these because they are quick to set up and in your face for most stuff,
whereas the digital snail scopes I use just for fancy capture work
You can't go wrong with a good analogue scope, and get a digital one later on.. if you need it
