1. Go to
mouser or the distributor of your choice
2. Look for N-MOS, filter for >500 mA, a threshold voltage <2V and maybe the package (smd, through-hole)
3. Order 100 of the cheapest
The majority of N-MOS on the planet should suit your needs. A typical jelly-bean is the
NTR4170.
(Bonus Points: Calculate on-state power and compare it to the datasheet's thermal characterisitcs, most should take your 400mA without hesitation, unless you plan to switch really rapidly)
