I'm going to help you out and serve you the answer on a silver plate, because you're clearly just going to forget it the very moment your professor gives you a passing grade.
Current through the coil equals:
$${I_{L,0-} = \frac{V_1}{R_1+R_2+R_3+R_4}=731.7\text{ mA}}$$
The current through the switch before switch-on is clearly 0, since current can't flow through an open circuit.
Now we close the switch.
The current flowing through the switch that is caused by the voltage source is:
$${I_{sw1,0+} = \frac{V_1}{R_1+R_2}=1.20\text{ A}}$$
But this isn't the only current that is now flowing in the circuit, you still have an energized coil in the circuit and it wants to resist the change of current. And it does, so in the very moment of switching, the current through the coil is still going to be exactly what it was before switching, except now it takes a different path, through the switch. The only difference is that we are observing the current flowing through the switch downwards, but the current from the coil is going to flow through it upwards, so we get a negative current.
$${I_{sw2,0+} = -I_{L,0-} = -731.7\text{ mA}}$$
The total current through the switch is simply going to be the sum of both currents. They partially cancel out
$${I_{sw,0+} = I_{sw1,0+}+I_{sw2,0+} = 468.3\text{ mA}}$$
_________________________________________________________________
Why do I have to know all of this theoretical garbage?
Learning and understanding things like calculus (beyond high school jokery), Fourier and Laplace transforms, differential equations and such have probably been the most valuable circuit analysis tools that I ever put in my toolbox. I only really started to appreciate this knowledge after I figured just how easy circuit analysis becomes if you attack the problems with this toolset.
I would rather learn about different circuit building blocks, like boost converters and RF filters, etc. Just to put application to these components, you know?
With this mindset, you're likely going to end up being one of those "SparkFun engineers", that just throw premade shit together and hopefully something
sticks ends up working (poorly), most likely due to sheer coincidence.
