Author Topic: Need help changing electric gate remote - thank you  (Read 2050 times)
Offline eevblogfanTopic starter
« on: June 12, 2013, 05:32:38 pm »
hey
I got two remotes , one is genuine and one I might be able to tweak to fit the task
the following pic is showing the output waveforms :
Re: Need help changing electric gate remote - thank you
« Reply #1 on: June 12, 2013, 05:56:19 pm »
the green wave is the okay remote . the one we need to copy
the yellow is the one we need to tweak
the boards :
the first board is the okay one
the others are :
1) botton side
2) upper side
« Last Edit: June 12, 2013, 05:58:20 pm by eevblogfan »
Offline Paul Price
« Reply #2 on: June 13, 2013, 03:36:24 am »
You can record the correct waveform for the control codes and then use a PICC or other MCU to generate these codes on button press and feed this to the modulate in lieu of the existing chip. I have done this with TV remotes to make remote controls to control other equipment and motors.
« Reply #3 on: June 13, 2013, 04:58:43 am »
First is a generic dip switch remote, while the others look like a rolling code remote. The top one is a $10 unit here, which is a learning remote that will record and play back the code from almost any non rolling code remote with no problem. The DIP switch ones are somewhat manufacturer dependant as they use slightly different timings on the same basic holtek code engine, which is a common item. Those cost from $5 depending on the type.
« Reply #4 on: June 13, 2013, 09:47:31 am »
they charge for 41$ for new remote , so I gave it a try
I don't know anything related to digital yet , is there any way you may help me with that ?
Offline amyk
« Reply #5 on: June 13, 2013, 10:57:36 am »
First one is a Holtek but I can't read the part number on it. Looks like a 12-bit code though.
The one you want to change is a PT2262 which is a 12-trit encoder. You can see the 10x2 solder pads + 2 buttons on the back.
If they work on the same frequency you could try setting the address using either 0 -> 0, 1 -> 2 or 0 -> 0, 1 -> 1 and compare the waveforms...
« Reply #6 on: June 13, 2013, 04:31:55 pm »
Depending on where you are I could probably post you some cheaper than the $41..........
« Reply #7 on: June 13, 2013, 06:53:48 pm »
hey
I am located in israel
these are not mine . they are Job ( although they are my father's friend )
