Beware when fitting data to an arbitrary equation. It is easy to convince yourself that the equation, not the data, is correct.
Your data seems to follow a simple curve, but may indicate different behavior for low values of the x coordinate. Either be suspicious of fitted behavior in this region, or look for reasons for changed behavior. A zener threshold crossed, or a stage saturated, or .....
