with that resume, she sounds like such a catch
I've been reading up on the picAXE. It looks like for my circuit, I can use that, along with ULN2803 to control the LED's and a couple of enable input voltage regulators to control the high side switching.
The ULN2803 takes up to 500mA per output, so that is more than enough for the LED's.
I'm still confused though on the programming. When it says to read analogue input value, and based on the voltage value, send pin C.1 high (for example). But the values are just straight numbers, like 50. Does that stand for 50mV or 50volts?
I understand that for seconds, 1 second real time equals 1000 for the value.
I might need to start a new thread for this.
