Hi everyone,
so, i have this board with a PIC16F1939 and an ENC28J60 chip on it, and i have tried to write some code for it, but it does not seem to work. Its supposed to make the 2 ethernet LEDs blink slowly. Here is the code:
spicom.c
#include <xc.h>
#define _XTAL_FREQ 32000000
void SPI_init(void)
LATA = 0x00; //Used Microchip Code Configurator to figure out the pins (for now)
TRISA = 0xFF;
ANSELA = 0x3F;
LATB = 0x00;
TRISB = 0xFF;
ANSELB = 0x3F;
WPUB = 0x00;
LATC = 0x00;
TRISC = 0xD7;
LATD = 0x00;
TRISD = 0xFF;
ANSELD = 0xFF;
LATE = 0x00;
TRISE = 0x0F;
ANSELE = 0x07;
WPUE = 0x00;
OPTION_REGbits.nWPUEN = 0x01;
APFCON = 0x00;
SSPSTAT = 0x00;
SSPCON1 = 0x20;
SSPADD = 0x00;
void SPI_writechar(char writechar)
SSPBUF = writechar;
void ENC_WCR(char adr,char value)
SSPBUF = (adr + 0b01000000);
__delay_ms(1);
SSPBUF = value;
main.c
#include <xc.h>
#include "spicom.h"
// CONFIG1
#pragma config FOSC = INTOSC // Oscillator Selection (INTOSC oscillator: I/O function on CLKIN pin)
#pragma config WDTE = OFF // Watchdog Timer Enable (WDT disabled)
#pragma config PWRTE = OFF // Power-up Timer Enable (PWRT disabled)
#pragma config MCLRE = OFF // MCLR Pin Function Select (MCLR/VPP pin function is digital input)
#pragma config CP = OFF // Flash Program Memory Code Protection (Program memory code protection is disabled)
#pragma config CPD = OFF // Data Memory Code Protection (Data memory code protection is disabled)
#pragma config BOREN = ON // Brown-out Reset Enable (Brown-out Reset enabled)
#pragma config CLKOUTEN = OFF // Clock Out Enable (CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin)
#pragma config IESO = OFF // Internal/External Switchover (Internal/External Switchover mode is disabled)
#pragma config FCMEN = ON // Fail-Safe Clock Monitor Enable (Fail-Safe Clock Monitor is enabled)
// CONFIG2
#pragma config WRT = OFF // Flash Memory Self-Write Protection (Write protection off)
#pragma config VCAPEN = OFF // Voltage Regulator Capacitor Enable (All VCAP pin functionality is disabled)
#pragma config PLLEN = ON // PLL Enable (4x PLL enabled)
#pragma config STVREN = ON // Stack Overflow/Underflow Reset Enable (Stack Overflow or Underflow will cause a Reset)
#pragma config BORV = LO // Brown-out Reset Voltage Selection (Brown-out Reset Voltage (Vbor), low trip point selected.)
#pragma config LVP = OFF // Low-Voltage Programming Enable (High-voltage on MCLR/VPP must be used for programming)b
void main(void)
OSCCONbits.IRCF = 0b1110; //8 MHz, 32MHz with x4 PLL
TRISA = 0;
TRISB = 0;
TRISC = 0;
SPI_init();
ENC_WCR(0x1F,0b11010010); //set Bank 3 in the ENC28J60
ENC_WCR(0x14,0x14); //set MIREGADR to PHLCON address
ENC_WCR(0x16,0b10111000);
ENC_WCR(0x17,0b00001011);
while(1);
spicom.h
#include <xc.h>
void SPI_init(void);
void SPI_writechar(char writechar);
void ENC_WCR(char adr,char value);
I have moved the topic from the Microcontroller & FPGA section to here
