Hello again.
I am trying to build a small power supply that will output 12V and 1A, with the input from a suitable wall wart. I already have that working with a LM7812, but that limits me to wallwarts that output at least 15V.
The I thought: why not have a circuit that will accept any wall wart from 6V to 20V (not precisely), and will output 12V/1A, as long as the wall wart has the proper current rating?
Then I though of 2 alternatives:
1) I have some MC34063 (and MC33063) ICs on my bin, but its datasheet only has circuits either for a buck or boost regulation, not for both. Is there any known schematic for this IC that will have a variable input and a fixed output? It will have to work as both buck and boost configuration.
2) Use a MAX668 in SEPIC configuration. Using Maxim's EE-Sim online tool, it proposed the circuit in the image below. Do you guys think this circuit will do what I want? Another thing: how the hell do I get a suitable resistor for R4 = 45.3mR ?
Thanks in advance.
