The eBay description of that board is useless. Do you need an input signal to Dir1 or Dir2 to specify direction?
From what I understand, the DIR pins are just for direction, high or low. That being said, I tried running 5V across it, and also tried putting the PWM signal from the Omega on it, no dice.
I've added some images in the attachments.
The PWM signal seems to go to pins 8 and 9 of the NAND gate. No-go on the schematics, so I don't know if there's any routing underneath the chip.
From the datasheet I can see that pin 8 is 'data output' and pin 9 is 'data input'. Seems a bit odd to me to have those coupled, but that's how it is.EDIT: I've misread the Gate chip, it's actually
74HC02D, which is a Quad 2-input NOR gate. The text I've written in the image would be wrong, that last 'D' looked like a '0' to me...
Pins 8(3A) and 9(3B) are both 'data input' .
What does the term 'data' suggest to you?
EDIT2: I added another image, where I've combined the two sides. The top (red) side routes that go under chips I tested with a multimeter...
All the MOSFETs are ST P75NF75, however some have a '&', some have a '@' at the end of the string (P75NF75& or P75NF75@)
