I would like some help with ID-ing these two components (inside red square).
On the left the "103" and on the right the "E01" (both ~ 1.5mm long). There both 8 pin. I tried (ofc) Google, but I'm not sure what it could be. Maybe a op-amp/comparator of some sort?
The 103 is connected via a flat cable to 2 momentary push switches (G, C an D). The Pins A, B, C and D are all getting 3.2V and G=Ground (0V). C and D are connected via the push switch to G (ground). The pins below I couldn't probe.
The E01, I have no further info on. Does'n seem to be connected to the flat cable at all (nevertheless, would like to know the chip).
Thanks!
