I've been working on a robotics project for a while, and I've come across some power problems. I need a *ton* of different voltages, and my original linear regulator design is really inefficient.
Here's what I need:
- 12 at 6-8 Amps (4 12v motors taking 2 Amps at max speed each)
- 10v for an (up to) 10 Watt LED (don't ask)
- 8v for motor controller and arduino (arduino has a built-in regulator)
- 5v to decrease load on the arduino's built-in regulator for high-power Ultrasonic and infrared sensors
Here's how I've been doing it:
- 3 * 7812 (2 amps) in parallel (big regulators are terribly expensive)
- resistor takes power from 12v regulators for LED (it dims when the motors start moving because the motors spike in power draw)
- 3 amp 7808 for motor controller and arduino
- arduino internal 5v regulator
BTW, this whole thing is powered by two 20c 7.4v Li-Po batteries in serial, nearing 12v when empty
as you can see, this is supremely suboptimal, and I need a replacement, however my electronics experience is practically nonexistent, I've only used development boards and made some simple sensors (e.g. high power reflected light sensor), so I need your help.
My fist thought was building a switch mode power supply for my 12v needs, and powering the rest via linear regulator. However there is a bunch of problems: I can't put anything behind the 12v regulators because the initial power draw from the motors is insane (Would a beefy capacitor help?), and I'm sure 78XXs don't appreciate PWM flicker that much.
So instead of putting the 8v stuff behind the 12v regulators, I have to put them in parallel, which brings me back to my problem of wasting a bunch of energy (12W according to my calculations).
What is an good solution to this problem? Every solution I come up with just ends up being a bad Idea in some way, and I'm sure there's a common way to deal with this.
