Can someone recommend a reliable 15V DC relay that can handle up to 20 amps continuously for periods lasting up to several hours?
I'm having trouble with the reliability of some relays in a custom race car application. There are several circuits that have high current loads that are supplied by relays that are controlled by SPST toggle switches. When I flip a toggle switch ON it closes the relay's control circuit energizing it's coil which closes the relay's internal output circuit supplying the load. When I flip the toggle switch OFF it de-energizes the relay coil and opens the output circuit turning off power to the load.
All of the loads in this car are designed to operate with input voltages in a range between 12 and 16 volts DC. The car's electrical system consists of a 12 V battery and an internally regulated alternator that supplies between 13.3 V DC and 14.75 V DC depending on rotational speed (RPM).
Some of the high current circuits in this car have loads that are used infrequently or only periodically and are in operation for short periods of time. Other circuits have loads that are in operation continuously, meaning 100% of the time that the cars engine is running. I have had trouble with the relays for the continuous duty circuits; they seem to go bad after some time. I don't have the same problem with the circuits that are operated infrequently or only periodically; those relays don't seem to go bad. All of these circuits are using the same style of relay from the same manufacturer.
Some examples of both types of circuits are listed below:
Examples of the infrequent or periodically operated circuits (these relays don't go bad):
- Starter motor circuit, operates only while cranking/starting the engine, can draw up to 50 amps for a few seconds
- Cooling fan circuit, operates only when engine coolant temp is higher than set-point, can draw up to 40 amps for periods usually lasting less than two minutes but sometimes up to 15 minutes or more
- Transmission brake circuit, operated very infrequently, can draw up to 5 amps for periods usually lasting a minute or two
- Line lock circuit, operated very infrequently, can draw up to 5 amps for periods usually lasting between 30 and 60 seconds
Examples of the continuous duty circuits (these relays go bad after some time):
- Fuel pump circuit, in operation 100% of the time that the engine is running, usually draws about 10 amps but can draw up to 30 amps for short periods depending on fuel demands
- ECU circuit (engine control unit), in operation 100% of the time the engine is running, draws anywhere from 1 amp to 16 amps depending on operational demands
- Ignition controller, in operation 100% of the time the engine is running, usually draws about 8 amps but can draw up to 13 amps for short periods depending on operational demands
As I said, I have used the same part for all of these circuits. The part is an integrated power relay module manufactured by Cooper Bussman. The datasheet is here:
http://www.waytekwire.com/datasheet/46094.pdfThe power relay module incorporates a relay manufactured by Song Chuan. The datasheet for the relay is here:
http://www.songchuanusa.com/wp-content/uploads/897.pdfOn the datasheet for the relay they specify expected life in terms of number of operations vs current. To me that indicates that the life of the relay is related to the number of times it is switched on/off and the amount of current supplied. In my application the relays that go bad are switched on/off very infrequently. Basically I turn them on once before starting the engine and they stay on for the entire time the engine is running until I turn the engine off. So I am not subjecting these relays to lots of switching cycles.
When one of these relays starts going bad it's output voltage begins fluctuating or dropping and then eventually it just doesn't provide any output voltage. This usually results in the engine dying, which can be quite dangerous if the vehicle is at speed and surrounded by other vehicles that are also at speed!
Do I have to just accept that relays go bad after some time if operated continuously? Or does someone manufacture a relay designed for this type of operation?
