I have a WES51 and if I'm not applying heat to a joint in the next minute or so, I turn the iron off. It only takes 15-20 secs to reheat and so far I am still using the original tip that came with the unit. I also have the temp knob set to 630 F (have no idea what the real temp is) and appears to work well with both 60/40 and 63/37 RMA solders.
