Author Topic: Need to convert DC-DC from 9V to 48V. Ideas?  (Read 13793 times)
Offline samsagazTopic starter
  • Country: ar
« on: December 15, 2011, 07:53:48 pm »
Hi guys, want to convert from 9V (battery) to 48V to use with MIC Phantom. I checked some circuits but see diferents alternatives, and cant decide wich one to choice.
I want to have high eff because want to operate the mic from an 9V Alkaline Battery and dont want to just get without charge in 1 hour.
these are some of the ics that i see
MC 34063
LT1054
LTC1144
LTC3872
MAX668
Btw, tha mics use like 10-12ma
Regards
Online IanB
Re: Need to convert DC-DC from 9V to 48V. Ideas?
« Reply #1 on: December 15, 2011, 08:57:39 pm »
Offline Psi
« Reply #2 on: December 15, 2011, 10:51:30 pm »
i'm not sure if this module is suitable because it outputs negative 48V, but if you want a pre-built solution
http://search.digikey.com/nz/en/products/NMT0572SC/811-1583-5-ND/1927144
- 4.5-5.5V input (so you can LDO 5V reg your 9V and you'll get pretty good usage out of the 9V down to 5V or so.
- Up to 21mA @ -48V when the other channels aren't loaded (-24V and -72V)
- small module
- relatively cheap, US$14
Actually, the datasheet says it's isolated between input and output, so you should be able to use it as +48V just fine.
« Last Edit: December 15, 2011, 10:54:12 pm by Psi »
Offline NiHaoMike
    • Facebook Page
« Reply #3 on: December 16, 2011, 12:27:39 am »
For such a low current, what about use a voltage multiplier?
  • Country: ar
« Reply #4 on: December 16, 2011, 01:33:56 am »
well, really dont know, where can i see wich are the best way to do that? i think that the best way will be the one that can let me use the 9V battery for long time. Will be great if the input can be 9 (battery) or 12v (Transformer).
Online IanB
« Reply #5 on: December 16, 2011, 01:54:18 am »
Doing a quick search for microphone phantom power supplies suggests that there is a bit more to designing them than just stepping up to 48 V. There are stability, regulation, lack of noise and other considerations to take into account. Why don't you just buy one that comes with good reviews rather than trying to make one?
Offline Zad
    • Digital Wizardry, Analogue Alchemy, Software Sorcery
« Reply #6 on: December 16, 2011, 02:46:21 am »
If you work out what sort of power it is drawing, and then calculate the current equivalent at 9V, you are looking at 100mA or so, even with a reasonably efficient converter. A 9V alkaline won't last very long. Maybe 2 hours, accounting for the reduced capacity at higher loads?
  • Country: ar
« Reply #7 on: December 16, 2011, 02:52:22 am »
Well i wanto to build my own one! if some companies make stable/reg/lack of noise ones, is not possible to get the same specs at home?
Offline Zero999
  • 0999
« Reply #8 on: December 16, 2011, 02:13:43 pm »
You could build a hybrid regulator. Use a DC-DC converter to get 52V and put an LM317 on the output to give 48V. This will give you low ripple, noise and excellent regulation.
  • Country: ar
« Reply #9 on: December 16, 2011, 02:37:06 pm »
wich DC-DC converter to recommend me?
« Last Edit: December 16, 2011, 02:57:45 pm by samsagaz »
Online ejeffrey
« Reply #10 on: December 16, 2011, 02:57:26 pm »
Put 5 9V batteries in series :)
Super low noise and will probably last 10 times longer than a single battery due to the conversion losses and capacity derating for high drain.
  • Country: ar
« Reply #11 on: December 16, 2011, 02:59:09 pm »
yeah, i think abt that, but are not to portable with 5 batteries, and battery price will be very high too :)
Online IanB
« Reply #12 on: December 16, 2011, 06:15:23 pm »
The battery cost will actually be lower using five batteries in series compared to one battery with a voltage converter. With five batteries in series the circuit will operate at 100% efficiency, whereas with one battery and a converter the efficiency will necessarily be lower. So over time you will buy more batteries in the single battery solution than the five battery solution.
Also I note that none of the commercial offerings are powered by a 9 V battery. Most of them use a 12 V DC wall adapter, and the few that are battery powered use bigger batteries like AA cells. If you think about it, 10 mA at 48 V is going to equal 50 mA at 9 V, then increase that to 70 or 80 mA due to conversion losses. That's a heavy load for a 9 V battery and it won't last very long.
Offline ciccio
  • Designing analog audio since 1977
    • Oberon Electrophysics
« Reply #13 on: December 16, 2011, 06:27:55 pm »
Phantom powered microphones have wide differences in power requirement: some work from 9 to 48 V, other don't work if powered with less than 40 V,  some use really low power, some drain a lot of current.
I don't know the mic you intend to use, so I'm not sure it will operate with  a lower than 48 V voltage.
Most of the microphones I've installed (and they are a really large number) worked flawlessly with a not standard 36 V dc supply (that happens to be the phantom voltage of the PA mixers I design and build).
Enclosed is a schematic I happen to have readily available: it's powered from a 12 V dc wall adapter, but adding other stages to the voltage multiplier it will operate from 9 V, or it will supply about 24-26 V dc if powered from 9 V.
regards
edit: disregard the preamp section, obviously...
Strenua Nos Exercet Inertia
I'm old enough, I don't repeat mistakes.
I always invent new ones
Offline ivan747
« Reply #14 on: December 16, 2011, 10:21:24 pm »
MC 34063
LT1054
LTC1144
LTC3872
MAX668
Regards
Do you want to connect a phantom microphone to a non-phantom console?
Offline Psi
« Reply #15 on: December 17, 2011, 12:12:51 am »
What about 12V A23 batteries
4 of them in series will give 48V
The energizer ones are rated at around 30mAh at 10mA discharge, so 3 hours worth.
If you put two packs of 4 in parallel (so 8 batteries) you'd get 6 hours.
And that wouldn't be huge, maybe the size of two 9volts.
  • Country: ar
« Reply #16 on: December 17, 2011, 05:40:30 am »
MC 34063
LT1054
LTC1144
LTC3872
MAX668
Regards
Well, im making a console, i already have the PREamp (DIY) using THAT1512 opamp, but now trying to add the phantom power. Mainly i want to use 12V DC from a 1A transformer, but want to add some way to make it portable, so i want to use 1 or 2 9V Batteries. Using 5 batteries y think that the weight will be high, and maybe the price too.
Offline DrGeoff
    • AXT Systems
« Reply #17 on: December 17, 2011, 06:10:29 am »
48V is a bit of a misnomer in this application, since it is not really a voltage source you are after. Phantom power specifies 48VDC in series with a 6.8K resistor on each of the hot and cold balanced leads with respect to the GND wire. What this really means is that the end voltage is 48V with no load. However if shorted the maximum current that can flow is 14mA. So with a 10mA load you really only have 14V at the load, not 48V.
Was it really supposed to do that?
  • Country: ar
« Reply #18 on: December 17, 2011, 08:41:59 am »
oh, i see, looks like not an easy task then :/
Online ejeffrey
« Reply #19 on: December 17, 2011, 09:33:27 am »
That doesn't really affect your job -- 48VDC through some resistors is still a 48 VDC supply.  Actually it makes things easier because it means phantom powered devices have to deal with varying supply voltages.  Iif your supply is 45 volts or 42 volts everything should still work.  You may have to tweak the feed resistors down slightly to compensate, especially for high current devices.
