Greetings!
I'm in the midst of trying to restore an old Rock-ola 454 juke from the early 1970's. When I got to the power amp section, two of the output transistors were missing. The transistors are 2N3055c, which , apparently, have been discontinued for quite some time.
I don't understand enough about transistors to determine if there is a suitable substitute. As I mentioned, the original is a 2N3055c. There are other variations that are still available, including the 2N3055 and 2N3055G. They seem similar. However, there are slight differences in their specs. Given the application, the differences may or may not be relevant. If there are any transistor gurus out there who can help, I truly would appreciate it.
Thanks!
