I noticed this. Americans historically used mmf and mf as measurements of capacitors (pF and uF) only and half the time they don't even add the units. This seems to have turned into a defacto standard in American literature. Then you have to decipher whether "47" means 47pF or 47uF. Here in Europe we adopted all of the correct symbols: F, mF, uF, nF, pF. 47u, 47p. Problem solved. Ultimately there should be no leading decimal portion of the number - just use the correct units!
Again diversion off
Just measured current between my ThinkPad T440 and ground: 82uA.
And the MacBook again: 103uA
Now my desk lamp which is a cheap shitty switch mode driven LED thing: 8uA.
Now I'm soaking wet after having just got out of the shower so not the best time to measure this
