Author Topic: New 2017 Macbook Pro 15 Inch giving me static electric shock. Is it normal?  (Read 27817 times)
Offline nasserprofessionalTopic starter
I recently bought a new Apple Macbook Pro 2017. When its plugged in charging I am getting an electro static shock from the aluminum body of the device. I have other aluminum apple laptops that dont give me static electric shock even if they are plugged into the same outlet etc.
I bought the laptop from Currys PC World here in the United Kingdom, England.
They insisted this is normal for Apple Macbook Pros and refused to give me a refund or replacement even though I am within the 21 days return period?
Is it normal to get an electro static shock from an Apple Macbook Pro 2017 15 inch?
I thought static electricity and elctrostatic discharge damages electronics/chips etc, thats why they have anti static packaging and anti static straps.
I would like to see what the electronics community has to say about this.
Sorry I hope I am not breaking any rules of the forum. I am extremley new to the forum but have watched Daves EEVBlog Youtube channel for a long time and would like your help.
« Last Edit: August 29, 2017, 12:03:20 pm by nasserprofessional »
Offline wraper
  • Country: lv
Does this happen when you are not touching anything else and is only a single shock and don't repeat if you touch again? Or is it a tingle feeling when you touch laptop and some other metal surface simultaneously?
It only happens when the laptop is plugged in/charging.
If I touch the laptop I can feel it the whole time I am touching the laptop.
Does it get discharged when I touch it? No, If I touch it again I can instantly feel it again so its still there the whole time and isnt getting discharged or anything.
It happens even if I am not touching any other surfaces while touching the laptop.
It happens even if I touch another surface thats grounded for example the wooden desk, the wall etc.
I have another Macbook Pro with an aluminium body I have tested that on the same surface, the same power socket, even had them side by side plugged into the same socket and if I touch the new apple laptop I can feel it if I touch the other apple laptop I dont feel it.
At first I thought maybe its just me so I let my mum and sister touch it and they both felt it as well.
I took it back to the store and they plugged it in, at first they denied everything said they couldnt feel a thing, they said nothing wrong with it but I could still feel the static electric or whatever it is going through the aluminum case even when it was plugged in at their store. Eventually after I kept insisting I could feel static electric or something they admitted they could feel it as well but insisted it was normal and that they all had apple laptops at home that do this.
I went upto the models they had on display and they didnt seem to have any issues. Not really sure whats going on but I believe its not normal as my other one isnt doing it at all.
They basically refused to do anything so eventually I walked out the store disappointed and I am trying to still talk to them about it. Just trying to find out if its really faulty or not.
Offline RGB255_0_0
Almost certainly Class Y leakage. Yes it's normal but you seem sensitive or their new charger is more susceptible to it. We've had this discussion in another thread regarding the missing ground pin; I can't remember which thread.
Measure the AC voltage between chassis and Earth and you're maybe seeing 60V+.
And next time tell the Apple idiot your statutory rights.
Your toaster just set fire to an African child over TCP.
Offline grumpydoc
It does not sound like a static shock, but rather you are feeling the small leakage current which flows through the EMI suppression capacitor in the charger.
However it is possible that the charger is faulty so it might be worth getting it tested by an electrician.
Or just try another charger.
The following users thanked this post: Kilrah
I also borrowed and tried a friends identical Macbook Pro 15 inch 2017 model with exact same specs in the same socket on the same surface and it doesnt have the same problem.
Im not sure if its to do with the earth. I dont think its to do with the earth though because I have another apple laptop that has a USA 2 pin plug on it so when thats plugged into a US to UK adapter into the same socket its definitely not earthed and even that doesnt give me a static electric shock?
Why is the brand new one giving me a static electric shock?
Just to be sure I also added the USA plug from the old laptop onto his new laptop and even after his new laptop definitely wasnt earthed it didnt do the static electric shock thing so I dont know whats going on.
What rights do I have btw, Just so I can tell those Currys PC World... guys? ;D
Offline frozenfrogz
  • Having fun with Arduino and Raspberry Pi
The thing with those shitty apple chargers is, that you need to use a three prong extension cord on them. With the two prong plug that comes with it the aluminium housing is not grounded (?) and there is electricity flowing on the surface.
Edit: Maybe it has to do with the phase and neutral prong also. I did not try that, but it might be possible that one way you are getting leakage current and plugged in the other way there is no leakage current.
« Last Edit: August 29, 2017, 02:04:01 pm by frozenfrogz »
He’s like a trained ape. Without the training.
Offline RGB255_0_0
Do you have a multimeter with AC range?
Online Ian.M
https://www.eevblog.com/forum/chat/does-this-sound-acceptable-for-an-apple-product/
See https://www.instrumart.com/assets/Megger-Portable-Appliance-Testing-Guide.pdf, page 20 Table 4.   If the supplied adaptor doesn't connect the Ground to the PSU stud, then it must meet the class II limit for touch current and if you measure more than 0.25mA AC between chassis and a good Earth, take it back and reject it as "Faulty, unsafe and not fit for purpose.". Return it about 9:30am* on a weekday ASAP, take a credible witness, and in case you have any problems, have your local Trading Standards on speed dial and your phone on speakerphone!   >:D
https://en.wikipedia.org/wiki/Consumer_Rights_Act_2015 sets out your right to a full refund within 30 days of purchase.
However odds are it will creep in under the threshold. :(
* So your local Trading Standards Officer has got into work, had his/her coffee and woken up!  ;)
« Last Edit: August 29, 2017, 02:52:06 pm by Ian.M »
Offline wraper
  • Country: lv
I also borrowed and tried a friends identical Macbook Pro 15 inch 2017 model with exact same specs in the same socket on the same surface and it doesn't have the same problem.
This is not static but current leakage, through Y capacitors. Have you tried changing only charger? The issue most likely connected with it. If other charger plugged in your laptop and the same socket does not experience this, there may be something wrong with your charger or it may be made by different supplier as Apple uses several PSU manufacturers.
Offline grouchobyte
  • Country: cn
Could be caused by a number of things. The hints in this thread might be helpful, but I would contact Apple first and foremost, since they are liable if you or someone else is hurt by this laptop.
My first  thought when I read the OP post was "sticker shock" ....ouch! (We need an emoticon for that)
@grouchobyte
Online Ian.M
No. Under UK law within 30 days of purchase, the O.P.'s first recourse is the shop that sold it.
See http://www.legislation.gov.uk/ukpga/2015/15/section/22
IANAL  :phew:
Offline brucehoult
I've had this with my 2011 17" MBP from time to time. It's sub-milliamp leakage current from the chassis not being at ground potential. In my experience it's nothing like a static shock. It feels more like getting a hair on my hands caught in a crack and being pulled. Mostly I notice it when I'm moving my hands across the surface, not keeping them still. It seems to depend upon where and how I plug it in. Right now it's plugged in to an Apple 85W power supply to  a NZ/Aus 3 pin lead to a NZ plugboard, to a cheap adaptor, to a Russian plugboard, to an extension cable, to the Russian/Euro earthed wall socket ("Schuko" I believe they're called). No problems.
Offline amyk
Yes, definitely the leakage current through the EMI suppression capacitor: http://www.aplomb.nl/SMPS_leakage/Doc_ie.html
Measure it with a multimeter. Feeling it doesn't mean it's unsafe, but you should still get a replacement if you don't like it. Some people are more sensitive than others.
Offline jmelson
REPLACE your charger immediately!  It has electrical leakage.  If you ever were to touch the computer and something grounded at the same time, you might get a serious shock.  If you can feel that electrical charge when you are not touching something grounded, then the case of the machine is likely at line potential.  You could check just the friend's CHARGER with your computer, and I'd give you a 99+% probability that you would not get the shock.  The problem has to be in the charger.
Jon
Offline Vtile
  • Ingineer
I would guess the float or not your scope.
Offline electrolust
Obviously this is not normal.  I assume you are using the Apple charger and not a 3rd party charger.
Too bad you didn't buy it from an Apple store.  Here in the US, and I suspect worldwide, I'm not sure of the time period but the return policy is for any reason whatsoever.  Since the apple store has a no questions asked policy, I'm surprised that 3rd party retailers aren't obliged to have the same return policy.
You might be lucky and it's just the charger.  So you'll be out the $50 or whatever but the fix is relatively cheap even without vendor support.  And don't buy from them again and give them a 0 star review.
Offline grumpydoc
If it is through the EMI suppression capacitor then a small amount of current is normal and allowed for in the safety standards.
However the fact that you can feel it on one macbook/charger combination but not another is suspicious that the charger is faulty.
Take it to an electrician who can do portable appliance testing - if it is outside the leakage limit (250uA if the charger is double insulated and has no earth connection) then you have a claim against the retailer.
If the charger is actually faulty then this claim is not limited to 30 days.
Offline electrolust
Normal vs. Allowed.
Allowed to the level that you would feel it?  With all the attention that Apple gets, if this were "normal" for apple products, the tech press would be all over it.  There is no possibility that this is normal.
Leakage on them is terrible. Periodically when I'm soldering my left elbow rests on the MacBook and also ends up feeding solder. You get an unpleasant tingle when you apply the iron.
This is normal. It's just shit.
Mine is 15" 2013 MBP bought from Apple Store.
If you take it back you'll get another one that does the same. Current is around 100uA max from what I measured at around 90v ac RMS. And it's normal SMPS leakage.
Incidentally my Thinkpad T440 does this but you don't notice it usually because the unit is entirely plastic. If you touch a port you will feel it.
Edit: before I forget, this caused havoc with an arduino I was using with an isolated floating supply. It caused the ADC to be entirely useless. I grounded the power supply and it was fine (and no more zaps)
« Last Edit: August 29, 2017, 08:18:48 pm by bd139 »
Offline jmelson
I really doubt the leakage is below 250 uA, or the OP would have been very unlikely to feel it.  I suspect it is WAY more than that.
Jon
Offline wraper
  • Country: lv
Jon
0.25mA feels quiet noticeably when current passes through you.
« Last Edit: August 29, 2017, 11:32:58 pm by wraper »
Offline John B
If you can't get an earthed 3 prong snub-nose adapter, you can always buy a cheap chinese 3 prong ~1.5m lead and then just trim the lead and put your own 3 prong connector on. That's how I made a short lead for the apple PSU.
As above, it's normal, but it's annoying. The tingling, even stinging feeling seems to punch well above its weight for what the 100-250uA RMS would seem to imply. When I made my thread I only measured current with a multimeter, I didn't examine the waveform.
Also worth noting, of the macbooks Ive tested, the chassis isn't conductive. Despite looking metallic, it's powder coated with an insulator, so the current is capacitively coupled.
To that end, the surface area of what is touching the chassis will influence the current you feel. If you directly touch the chassis with a probe lead, the voltage and current will be less compared to placing a metal plate on the chassis then touching your probe to that.
« Last Edit: August 29, 2017, 10:18:26 pm by John B »
Offline electrolust
Jon
0.25A feels quiet noticeably when current passes through you.
the number being discussed is .000250A, not .250A
Offline electrolust
many discussions about this if you google search.  apparently it is not uncommon for non-3-prong plugs.  I think the apple charger itself is only 2 prong if you don't use the long extension cable.
