I've just started launching into electronics (after dropping out of an engineering degree 10 years ago), and one of the first things I grabbed was a Rigol DS1052E.
I was doing some testing of USB adapters this eve and discovered that on my 1052, there was about a 20mV difference between CH1 and CH2 (using the same probe).
How I noticed it: I had two USB cables modified to have the ground and +5V exposed, connected in a chain, and had one probe hooked up to each (one on CH1, one on CH2; both set to 10x). I set the offset to 5.15V and scale to 20mV/div on both (via VISA from computer). There was a small difference in V (i.e. 5.14V vs 5.16V) between the two, which seemed a bit odd. I pulled everything apart, plugged in one cable directly to the adapter, hooked a probe (still on 10x) up to GND and +5V, and connected it to CH1. Took a reading. Swapped the connector to CH2; different by ~20mV.
My response: I disconnected the probes and performed self-calibration (after leaving the 1052 running for 30 mins) and tried again. Same result.
The question: Is this normal? Should I be expecting an error of 20mV (when using probes on 10x) between CH1 and CH2 on a ~5.15V signal at 20mV/div?
Note: the 1052 came with 00.04.01. It was modded to an DS1102E for about 1/2 an hour using the file linked
on the 1052e to 1102e thread, and then switched back using the same file with the patched by returned to the '50MHz' value (i.e. from 01 to 09, based on
this post). There were no apparent problems with the update, nor the return to 50MHz. I just changed back because I figured I would maintain it in 'factory' state until necessary.
If there is important information I've not included, please let me know and I'll add it.
