Thanks for your reply and i intent to get into smd repairs ya see mobile phones tablets and laptop repair so i need both i think what do u think to the chinese replicas?? Or do i need to spend my money just the hotair and but a cheap solering station?
You'd be surprised at how much you can do with an iron, including SMD work (BGA is the one thing that an iron can't be used for). So most of us tend to recommend going with a better quality iron, and Chinese for hot air, as the name brand stuff tends to be too expensive for the majority of hobbyists (~$600USD to ~$2kUSD new, depending on features & accessories <nozzles>).
I'm also a fan of separate units, as it can allow you to use one to fix the other (i.e. use the good iron to fix the broken hot air station when it happens).
A pre-heating plate was mentioned, and would be a nice edition, particularly on multilayer boards that can draw heat away from the joint/s you're working on. But it's not within your budget right now, so would be something to do last. And only then if you actually need it. Another thing you could look into at a later time, would be modifying a toaster oven into a reflow oven (How-To's available on the internet). Again, only if you need it at some later date.
Check YouTube to see what's possible with SMD and an iron ("drag soldering" would be one to look for).
A couple of other places you could look to purchase Asian made goods, would be deal extreme (
dx.com) or
Aliexpress. Both are Asian suppliers, but are reasonable on prices & shipping (look at the totals <item + shipping).
