Hi all, I'm new to this hobby, and just in the beginning learning stages. I just purchased the book Make Electronics, a bread board, a Klein mm1000 DMM, and just ordered a Korad power supply. Been having a blast going through the first chapters of the book. Never dealt with these DC power supply's before, and just want to make sure I understand this. If I set the volts to say 6.3, and hook the outputs to a 1K 1 watt resistor, the circuit should pull about 6.3mA's. So I preset the volts to 6.3, the amps to maybe 100mA's, and the circuit will only draw the 6.3 mA's it needs correct? So theoretically I could set amps to 7mA's, and the supply should power the circuit fine right?
