Here's my tunnel diodes. I bought them a while back on eBay but never have time to actually do anything with them. The diodes are made of Ga-As, and specified
as 'switching type'. Units in this package have been selected at the fab for the peak current of 10 mA, about 30 years ago.
I connected one of the units to the power supply and made an
I-V graph, in 10 mV increments. It starts oscillating at 200-ish MHz past the peak, I also observed a swith to 400-ish MHz at ~0.4V. Minimum current at valley is
less than 1 mA (supply shows 0A) and my setup also stops oscillating around this point.
If anyone is curious about numbers,
the spreadsheet is available here ->
https://docs.google.com/spreadsheets/d/1N-ZOeQkQ03KiGugnZ2T3KB9yKxSpm3ScF7_YWaIBdn0/edit?usp=sharingAll values are taken directly from the supply's display, previously checked against calibrated HP34401A (can't use it here, any length of wire makes big mess).
Tektronix 7104 scope, 7A24 500 MHz plugin, 7B10 time base, P6201 900 MHz 3pF FET probe, DC-coupled, ground on the center line.
The next step is to make a TD pulser described in Picosecond Pulse Labs Application Note AN-19. After Tektronix bought PSPL none of their excellent appnotes are
available from a single place; however, they can still be found on third-party sites that care,
such as this one ->
http://tec.icbuy.com/uploads/2013/2/1/AN-19%EF%BC%9APicosecond_Pulse_Generation_Techniques_and_Pulser_Capabilities.pdf . It seems
that this particular diode will give me more than 0.5V step and pulse can be made up to tens of microseconds long. The terminal capacitance at valley is specified
at 10 pF, the formula on page 6 predicts 1 us rise which seems low given the frequencies at which the diode manages to oscillate - we shall see.
