Hello All,
I'm new and I have a question to ask about the fuses in my apt. Not making any repairs, but my superintendent is kind of useless/unavailable so I figure the more
I know myself, the better, so that I can be prepared and prevent needing to call him as much as possible.
I live in a pre-war building. In my apartment unit, there is a small fuse box with 2 sockets to use Amp plug fuses. Apparently, the main fuse box is in the basement of the building and I do not have access to it, only the super does. Whenever a fuse blows, I have to call him (if he answers the phone) and I guess he has to replace the fuse in the main box. When I first moved in, there was a 30A TL type fuse and a 20A TL type fuse screwed into the box in my unit, so of course, these are the fuses I stocked up on. I understand space heaters are "electrically expensive" so to speak; however, I have needed to use one this winter. After blowing the fuse MULTIPLE times, I have since learned that the space heater cannot be used with any other appliances in order to keep the electrical peace. The last time it blew, the super came to ask me if I had a 15A S type fuse because he ran out. I was shocked to hear that he needed 15A because I have at least 50A capacity screwed into my individual unit. I also found out that MY fuses do not actually burn, so I rarely need to change them, it is usually the fuse in the box in the basement. My questions are:
1. Can I stock up on and give the super a Cooper Bussmann 15A circuit plug breaker? Is that compatible/easier for him. (i'll keep my own supply as well, just in case)
2. I am VERY concerned now about the safety of my circuit. Am I using the WRONG (too many amps) fuses in the box in my apartment unit?
3. If the fuse that is burning is the one in the main box in the basement, then what is the box in my individual unit even for? Is it functional? How does it relate to my outlets/ electrical usage?
Any help or advice would be greatly appreciated. I've looked up different types of fuses, compatible wire guages, etc., but since I don't have access to the main box, I don't know how much I could find out.
Thank you in advance.
