Author Topic: newbie mistake wrong fuse  (Read 6015 times)
Offline allobyTopic starter
Re: newbie mistake wrong fuse
« Reply #25 on: December 19, 2017, 12:24:07 am »
Thanks I will check that cap tomorrow and let you know is it best to check out of circuit .
Offline Paul Moir
« Reply #26 on: December 19, 2017, 12:34:09 am »
Check it in circuit first.  You may see your multimeter numbers climbing up as the capacitor charges if everything is good.  There are very few (no?) cases where a capacitor is shunted by a low value resistance.
If you do get a very low resistance then think about taking it out, but I would suspect the load that this capacitor is smoothing the output of the bridge rectifier for rather than the capacitor itself.
« Reply #27 on: December 19, 2017, 02:12:29 pm »
I need to read up how to check it properly also can anyone tell me if a rwm 6x 22 RB57 will be ok instead of rwm 4x22 RB61 I am having trouble finding a RB61 but RS stock RB57 thanks in advance.
« Reply #28 on: December 19, 2017, 03:04:25 pm »
I checked the capacitor its a 47micro farad 400v and off the board it reads 52.6 micro farads and it charges up and discharges so I assume it is ok.I also reversed my leads and still read 52.6 micro farads.
« Last Edit: December 19, 2017, 03:23:03 pm by alloby »
« Reply #29 on: December 19, 2017, 04:14:57 pm »
I have just doubled checked bridge rectifier and I had a measurement wrong
The bridge rectifier reads red probe on + black probe on 1st ~ =OL
                                      red probe on 1st ~ black probe on + =0.0550
                                      red probe on  1st ~ black probe on 2nd ~ =0.0546
                                      red probe on 2nd  ~  black probe on first ~  =OL
                                      red probe on -    black probe on 2nd ~ = 0.543
                                      black probe on -   red probe on 2nd   ~ =OL
                                      red probe on 1st  ~ black probe on  - = beep or 0.001 and black probe on 1st  ~ red probe on - =beep
                                      black probe on -    red probe on 2nd  ~ = 0.0543  this is now correct
                                      red probe on +   black probe on 2nd ~ =OL
                                      black probe on +   red probe on 2nd   ~ = 0.547
I entered it wrong first time so can anyone confirm it is still faulty
Offline Dbhrs
« Reply #30 on: December 19, 2017, 04:27:53 pm »
I would say that one internal diode is shorted. So it is faulty
I don’t have very much experience with this so someone may say different.
Sent from my iPhone using Tapatalk Pro
« Reply #31 on: December 19, 2017, 04:34:28 pm »
Thanks I hope so I have double checked and that was the only one I had wrong
Offline WaveyDipole
« Reply #32 on: December 19, 2017, 08:49:04 pm »
Yes, the rectifier is faulty. I was trying to ascertain whether it had become stressed by a short across the smoothing cap. Sounds like the cap is Ok so there must be another explanation for the rectifier failure.
Offline james_s
« Reply #33 on: December 20, 2017, 01:41:33 am »
Occasionally rectifiers just fail, I wouldn't spend much time looking for the fault. Especially in low cost Chinese gear it was probably spec'd for the lowest cost possible and may have been of questionable quality to begin with.
Offline ggkios
  • Country: gr
« Reply #34 on: December 20, 2017, 04:16:10 am »
Hes got a jbc, starting price for one is around 500$, but yeah i sometimes bridge rectifiers fail
???????? ??? ?? LG-D855 ??? ??????????????? Tapatalk
« Reply #35 on: December 20, 2017, 04:43:12 pm »
I have ordered the exact bridge rectifier part but I cant find exact resistor rwx422 rb61 6.8ohm 7w so I have ordered Vishay RWM 6x22 rb57 Series Axial Wirewound Resistor 6.8? ±5% 7W ±75ppm/°c I am thinking they will be ok so if anyone thinks they are not suitable let me know
« Last Edit: December 20, 2017, 04:48:08 pm by alloby »
« Reply #36 on: December 25, 2017, 03:07:21 pm »
I have received new bridge rectifiers and after testing it confirms my one was faulty I am just waiting for resistors and will update when they arrive.
« Reply #37 on: December 29, 2017, 04:17:43 pm »
 I got my resistors in post and soldered it on board along with bridge rectifier put new fuse in and it works,I cant believe it so thanks to everyone who helped, to some it might have been an easy fix but to me I felt I was out of my depth but now I have more confidence in myself and it has helped me to think about what is happening in a circuit I feel I have learnt a lot and this forum is the reason why so again a big thank you and hope everyone has a prosperous new year.
The following users thanked this post: Ian.M, newbrain
Offline ggkios
  • Country: gr
« Reply #38 on: December 29, 2017, 04:24:21 pm »
Glad it worked, hopefully it will stay this way
The following users thanked this post: alloby
Offline Gyro
« Reply #39 on: December 29, 2017, 05:00:19 pm »
Congratulations on the successful repair alloby.  Best wishes for the New Year.
Best Regards, Chris
Offline Dbhrs
« Reply #40 on: December 29, 2017, 11:22:50 pm »
Congratulations and Happy New Year
Offline gaborgabor
  • Country: hu
« Reply #41 on: May 30, 2020, 04:06:25 pm »
Hi everybody !
I would like the JBC JT-2A service manual, or schematics, or circuit diagram.
Do you have it ?
Thank you for your help!
Best Regards,
Gabor
Offline gaborgabor
  • Country: hu
« Reply #42 on: May 31, 2020, 05:27:55 pm »
Hi , i have a question...
What is the type number of the IC on the picture ( in the red circle )
Thank you for your help.
Best Regards,
Gabor
Offline Jontm
« Reply #43 on: July 29, 2020, 08:00:46 am »
Sorry to bump an old thread, but i had the exact same issue.
Seems like the bridge rectifier for the air is a common failure mode on these. Did not find this thread when searching for some reason, might have saved me the 250 USD i paid for a new heating element hoping that would solve the issue.
The unit i have is a JBC JT-2A hot air station.
The bridge rectifier in question is a DIOTEC B500C1500B. It has a bit unusual pinout so i have not been able to find a substitute (~+~-) Edit: Vishay VS-2KBB100 seem to be equivalent. Have ordered one as it is easier for me to get hold of than the DIOTEC B500C1500B.
Hopefully this will help somebody else having similar issues :)
PS: gaborgabor: The IC you are looking for is a Vishay BRT23M optocoupler. Seems like it is obsolete and out of production, but i am sure that there are some similar triac optocouplers with similar specs and package type available if you spend some time comparing the datasheet with filters on mouser/digikey/farnell/or others.
« Last Edit: July 29, 2020, 12:54:45 pm by Jontm »
Offline delfinom
« Reply #44 on: August 11, 2020, 06:04:28 pm »
Just going to throw in a comment as well for future searchers. We had a power surge that blew a bit of various equipment. The Bridge rectifier was indeed the part that failed on our JT-2A as well. I just bodged in a normal pinout bridge rectifier but just twisted the legs and expoxied them to keep em apart heh.
