Driving an IR LED from an MCU, typically requires a P-channel FET as I have seen on several diagrams now. Since I only have small signal N-channel FET's laying around, can I simply move the resistor and LED from behind the drain, up in front of the source like you would do with a PNP -> NPN bipolar?
