Author Topic: Newbie Rigol DS1050E Question  (Read 5198 times)
Offline VeramacorTopic starter
« on: November 25, 2009, 01:13:22 am »
Fellow Rigol owners,  or experienced O-scopers for that matter,
I've been trying to zoom in on a 9-Volt battery signal's noise recently.  No problem aquiring the signal (around 7.8 volts).
The problem I have is when I attempt zoom in on the DC signal, by using the vertical scale knob down to say 100mv/Div,  I cannot re-center the 7.8 V signal on the screen as I have reached the scale limit.
Is there a way to reference the 7.8V signal on the center of the screen without the vertical scaler repositioning the signal?
I'll try to explain again later if I'm making myself unclear,
J
« Last Edit: November 25, 2009, 01:15:12 am by Veramacor »
Offline Zero999
  • 0999
Re: Newbie Rigol DS1050E Question
« Reply #1 on: November 25, 2009, 01:20:56 am »
You should use the AC coupling function to view an AC signal suppressed on a DC signal.
To measure DC you should use a DVM which is more accurate at DC.
« Reply #2 on: November 25, 2009, 01:49:51 am »
Thanks that was a bit of a stumbling block!
V
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #3 on: November 27, 2009, 05:29:04 pm »
to be honest your going to see more internal scope noise than the noise on a 7.8 power line so if it looks nasty: don't worry
