I concur. The Maha is also the only charger I know that will do the IEC 61951-2 c2003 to verify the true capacity of the battery; this is the procedure by which any official label on the battery mAH must be based on.
Based on the label and the Maha C9000, my eneloops and a Chinese LSD NiMH sold in the the US as Tenergy Centura, live up to their labels.
In addition, 3 years later, the batteries I quick charge using the Maha algorithms
have not aged based on the IEC test, because I checked their IEC capacity when I first bought them, and rechecked them periodically.
I have a set of no-name NiMH that has reduced its aging rate after I began using the Maha on it, it was 2000 mAH when new in 2003, 1600mAH at the start in 2010, and 1400mAH 2 days ago.
The problem with a trickle charger is if it has no feedback circuits; no over temperature or end-voltage slope compensation. The internal resistance in some batteries may rise temporarily so the battery's overheat during a charge; the response is to hold the charge until the battery's cool down even if the rate is 0.1C, unlikely as that seems. Repeated pulsing between charging and a no-charging state, this internal resistance may be dissipated thus, revitalizing an old battery, keeping old one's 'young'; its suspected to be caused by gas bubbles within the electrolyte that return into solution during the pulse charging effect. So if you charge a battery using a passive constant current charge, and the cells temperature rises >=45
oC, this is total temp casing + ambient, the cells mAH will be reduced or cell destroyed.
During my evaluation of the Maha and since then, I've never had a battery charged go above 40
oC, at most its been < 38
oC measured with an IR thermometer calibrated against a Fluke thermocouple.
It is a magnificent technical charger; my only gripe with the C9000 is the user interface design.
For my money the Maha C9000 is the best choice as a desk top, regular everyday charger. It has some flaws, but overall it just does what it is supposed to do in a reliable manner, day in, day out. Once you have got used to seeing exactly what your cells are doing and how they are performing, and exactly what state of charge they are in, you will find it hard to go back to a simple charger with no display.
That said, slow charging at 0.1C is an option and it will certainly work. In the long run, however, it may wear out your cells prematurely.
